Heat resistant steels, typically Cr-Mo steels, have been widely utilized under such high temperature and high-pressure environments as thermal power plant boilers (hereinafter called boilers).
These steels are classified in Japan by the Japanese Industrial Standard (JIS) and overseas by the standards of both American Society for Testing and Materials (ASTM) and American Society of Mechanical Engineers (ASME).
The classification of welding consumables for heat resistant steels is also regulated by JIS in Japan and by both AWS and ASME standards abroad.
Table 1 shows Kobe Steel’ s line-up of heat resistant steel welding consumables (1.25Cr-0.5Mo and 2.25Cr-1Mo steels) for boilers.
Kind of steel | ASTM | SMAW | GMAW | GTAW | SAW Flux/Wire |
FCAW |
1.25Cr-0.5Mo | A387 Gr.11 Cl.1, 2 A213 Gr.T11,12 A335 Gr.P11,12 |
[T]CM-A96 [T]CM-B98 |
[T]MG-S1CM [T]MG-S80B2F |
[T]TG-S1CM [T]TG-S80B2 |
[F]G-80/ [T]US-511 [F]G-80/ [T]US-B2 |
[T]DW-81B2C[CO2] [T]DW-81B2[Ar-CO2] |
2.25Cr-1Mo | A387 Gr.22 Cl. 1, 2 A213 Gr.T22 A335 Gr.P22 |
[T]CM-A106 [T]CM-B108 |
[T]MG-S2CM | [T]TG-S2CM [T]TG-S90B3 |
[F]G-80/ [T]US-521 [F]G-80/ [T]US-B3 |
[T]DW-91B3C[CO2] [T]DW-91B3[Ar-CO2] |
Figure 1: Comparison of arc time by welding processes
SMAW, SAW, GMAW and GTAW are the welding processes commonly applied to fabricate boilers;however, flux cored wires (FCWs) provide higher efficiency than TIG filler rods (GTAW) and covered electrodes (SMAW) as shown in Figure 1. With their ability to create superb bead appearance even in such severe positions as on fixed pipes, FCWs have become mainstream in most shipyards. Hence, it is expected that FCWs will expand to industries requiring heat resistant steels such as boiler fabrication in the near future.
In this article, FCWs for 1.25Cr-0.5Mo and 2.25Cr-1Mo heat resistant steels that conform to AWS specifications will be discussed.
Kobe Steel’s selection of FCWs for heat resistant steels is shown in Table 2. They are classified according to the steels and shielding gases as specified by the AWS while also conforming to ASME’s F-No. and A-No.
100%CO2 | Ar-20%CO2 | ASME F-No. |
ASME A-No. |
1.25Cr-0.5Mo | [T]DW-81B2C [AWS A5.29 E81T1-B2C] |
[T]DW-81B2 [AWS A5.29 E81T1-B2M] |
6 | 3 |
2.25Cr-1Mo | [T]DW-91B3C [AWS A5.29 E91T1-B3C] |
[T]DW-91B3 [AWS A5.29 E91T1-B3M] |
6 | 4 |
AWS also specifies Post Weld Heat Treatment (PWHT) at 690℃ for 1 hour (690℃x1h). Because PWHT is usually carried out in practice, it is necessary to design welding consumables that provide excellent mechanical properties after PWHT by taking the following points into consideration:
(1) minimizing impurities such as P & S in raw materials;
(2) designing for low C and high Mn in order to provide moderate hardenability and to stabilize notch toughness;
Tables 3 and 4 show typical chemical compositions and mechanical properties after PWHT of the deposited metals, respectively. Both chemical compositions and tensile properties satisfy the AWS requirements, and the impact properties at room temperature (+20 ℃) are sufficient.
Kind of steel | Trade designation | Shielding gas | C | Si | Mn | P | S | Cr | Mo |
1.25Cr-0.5Mo | [T]DW-81B2C | 100%CO2 | 0.05 | 0.21 | 0.96 | 0.009 | 0.004 | 1.22 | 0.50 |
[T]DW-81B2 | Ar-20%CO2 | 0.06 | 0.29 | 0.97 | 0.010 | 0.005 | 1.30 | 0.50 | |
AWS A5.29 B2 |
Min Max |
0.05 0.12 |
- 0.80 |
- 1.25 |
- 0.030 |
- 0.030 |
1.00 1.50 |
0.40 0.65 |
2.25Cr-1Mo | [T]DW-91B3C | 100%CO2 | 0.06 | 0.18 | 0.99 | 0.007 | 0.004 | 2.26 | 1.00 |
[T]DW-91B3 | Ar-20%CO2 | 0.06 | 0.29 | 1.12 | 0.008 | 0.004 | 2.38 | 1.01 | |
AWS A5.29 B3 |
Min Max |
0.05 0.12 |
- 0.80 |
- 1.25 |
- 0.030 |
- 0.030 |
2.00 2.50 |
0.90 1.20 |
Kind of steel | Trade designation | Shielding gas | PWHT condition |
0.2%YS (MPa) |
vE+20℃ (J) |
1.25Cr-0.5Mo | [T]DW-81B2C | 100%CO2 | 690℃x1h | 539 | 619 | 23 | 54 |
[T]DW-81B2 | Ar-20%CO2 | 570 | 654 | 22 | 31 | ||
AWS A5.29 B2 |
677-704℃ x1-1.25h |
Min.470 | 552 - 689 |
Min.19 | - | ||
2.25Cr-1Mo | [T]DW-91B3C | 100%CO2 | 690℃x1h | 571 | 659 | 22 | 82 |
[T]DW-91B3 | Ar-20%CO2 | 621 | 696 | 22 | 111 | ||
AWS A5.29 B3 |
677-704℃ x1-1.25h |
Min.540 | 621 -758 |
Min.17 | - |
Figure 2: Applicable ranges of welding current and arc
voltage by welding positions
In Kobe Steel’s FCWs for heat resistant steels, slag forming agents like a rutile (TiO2) are added in order to improve usability in all position welding. Figure 2 shows applicable ranges of welding current and arc voltage in horizontal fillet and vertical upward welding. Accordingly, welding current can be as high as about 300A in horizontal fillet welding and 240A in vertical upward welding. Also, a wide range of arc voltage canbe used.
Figure 3 shows bead appearances and cross-sectional macrostructures in horizontal fillet and vertical upward welding, respectively. In addition to obtaining sufficient penetration and a sound weld toe, no large particle spatter adhesion appears, the bead shape shows little unevenness, and bead appearance is glossy.
Figures 4 and 5 indicate the mechanical properties under various PWHT conditions including the as-welded condition for reference.
With regard to 0.2% offset yield strength (0.2%YS) and tensile strength (TS), the FCWs fully satisfy the lower limits of those of the base metal even under such high temperature and long time PWHT conditions as 690° C x 4h. On the other hand, it is more effective to perform PWHT under higher temperature (650℃→690℃) and longer time (1h→4h) in order to get better impact properties.
Figure 6: Diffusible hydrogen content of weld metal
Figure 6 compares the diffusible hydrogen content of the weld metals with FCWs for heat resistant steels with that of a solid wire (GMAW) and a covered electrode (SMAW).
The FCWs’ diffusible hydrogen content is from 2 to 4ml/100g which is inferior to that of [T] MG-S1CM (GMAW) but, almost equivalent to that of [T] CM-A96 (SMAW).
Each of the above tests was conducted right after the package of welding consumables was opened. However, because of moisture absorption by or adherence to the welding consumables, diffusible hydrogen content may increase if the welding consumables are left in the packages for long periods after unsealing. It is, therefore, recommended for the consumables to be used promptly once their packages are opened.
In actual welding of heat resistant steels, PWHT is erformed to improve weld metal impact properties and lso to remove residual stresses. However, stress relief (SR) cracking or reheat cracking may occur during the PWHT process. Two reasons are widely recognized as the cause of SR cracks.
The formula of SR crack susceptibility for precipitation hardening is as follows:
The above formulae show that Cr, Mo, Ti, V and Nb are the elements that lead to the formation of precipitate and weakening of SR crack resistance. However, it is important to note that these concerns are more relevant to heat resistant steels than carbon steels, because Cr and Mo are principal and unavoidable elements in heat resistant steels.
In this regard, the rutile (TiO2) is another important aspect in the design of FCWs for heat resistant steels. Although it is commonly utilized in all-position-type FCWs as a slag forming agent, the Ti element decomposed from TiO2 inevitably mixes into the weld metal, resulting in reduced SR crack resistance. There is also a possibility that V and Nb may mix into the weld metal as they are unavoidable impurities in the raw materials for welding consumables.
FCWs for heat resistant steels must be carefully designed from the SR crack point of view. In Kobe Steel’s FCWs for heat resistant steels, impurities in the raw materials are strictly controlled, resulting in the achievement of excellent SR crack resistance.
Two evaluation methods of SR crack resistance are available: the high temperature/-slow strain rate-tensile test and the C-shaped ring cracking tes t. Figure 7 compares the reduction of area after fracture in the high temperature/-slow strain rate-tensile test.
When the reduction of area after fracture is low, SR crack resistance is poor. The FCW with no control of impurities resulted in a low reduction of area after fracture. By contrast, [T] DW-81B2 FCW, in which impurities are controlled, had nearly the equivalent reduction of area after fracture as [T] CM-A96MBD, a covered electrode that is utilized in the welding of pressure vessels.
Figure 7: Comparison of reduction of area after fracture
in high temperature-slow strain rate-tensile test
Figure 8: Observation of crack or no crack at U notch
portion in C-shaped-ring cracking test
The results of the C-shaped-ring cracking test are shown in Figure 8. It can be observed that the crack occurred with the FCW with no control of impurities, which was the same FCW as the one shown in Figure 7. On the other hand, no crack occurred with [T] DW-81B2 FCW, in which impurities are controlled. These results demonstrate that [T] DW-81B2 has excellent SR crack resistance.
In welding, the PWHT condition should be determined by considering the required mechanical properties, even though FCWs for heat resistant steels show good mechanical properties within the range of 650-690℃x1-4h as shown in point 4, above (Mechanical properties of FCWs for heat resistant steels under various PWHT conditions).
Figure 9: Cross-sectional macrostructure showing ferrite
band generation (PWHT: 710℃x24h)
For example, under the high temperature and long time PWHT condition like 690℃x4h, FCWs’ 0.2%YS and TS can fully satisfy the lower limit of those of the base metal, and it is advantageous to improve impact properties. On the other hand, if excessive high temperature and long time PWHT is performed, it will cause the formation of a soft structure called the ferrite band and may result in extreme decreases in TS and notch toughness.
It is, therefore, recommended to conduct a confirmation test in advance to determine whether the mechanical properties will satisfy the requirements when excessive high temperature and long time PWHT exceeding 690℃x4h is applied.
Finally, it is not recommended that the FCWs discussed above be applied in the welding of pressure vessels or parts requiring pressure resistance that specify low temperature toughness. The application of these FCWs should be utilized on parts with no strict toughness requirements, or, in other word, with no pressure resistance requirement.
In this article, the FCWs for 1.25Cr-0.5Mo and 2.25Cr-1Mo heat resistant steels that conform to AWS standard were discussed. They are designed to fulfill requirements not only for chemical compositions and tensile properties but also for impact properties. Furthermore, as they are aimed to decrease the SR crack susceptibility that is peculiar to heat resistant steels, it is hoped that these FCWs will contribute to the improvement of welding efficiency.
Upon reflecting on feedback from customers who apply these welding consumables onsite, Kobe Steel will make utmost efforts to further improve the properties of these FCWs.
[References]
1. The Journal of The Japan Welding Society, 1992 Vol. 61, No. 6,p469-p472
2. API RP 934-A, 2012, Addendum 2, Annex B
3. The Journal of The Japan Welding Society, 1964 Vol. 33, No. 9, p718-p725
