Submerged Arc Welding (SAW) is one of the principal arc welding processes. It accounts for about 10 % of all arc welding. By country, China consumes more than 50% of SAW consumables and is followed by Europe, North America, Russia and Japan. As for industries, SAW is used primarily in the fabrication of steel pipes, steel structures, bridges, ships and chemical plants due to the long straight welding lines that are common in these structures.
In Japan, the SAW consumption ratio by industry is nearly the same as that for the world except for steel pipe, which accounts for a much lower share of SAW consumption.
Flux type | Notch toughness at low temperature |
Moisture absorption resistance |
Diffusible hydrogen content |
Flux consumption ratio | Efficiency | Kind of electric power |
Fused | Average | Best | Low | Average | Average | AC |
Bonded | Good | Average | Lowest | Low | Best | AC / DC |
Agglomerated | Good | Good | Low | Low | Good | DC |
Table 1 shows the characteristics of the three types of SAW fluxes: fused, bonded and agglomerated. In the Japanese market, SAW fluxes suitable for alternating current (AC) have been favored because of the relatively lower cost of AC power sources in comparison with direct current (DC) ones. Bonded fluxes, designed for both AC and DC, were also developed in Japan. However, while these fluxes were mainly used for large heat-input welding, the agglomerated fluxes, applied for general-high speed welding with DC, were in demand in the overseas markets.
To respond to the needs of global markets, Kobe Steel has been pursuing the development of SAW consumables designed for use exclusively with DC and is now pleased to announce the availability of agglomerated flux. Naming its first SAW flux of this type “AF,” Kobe Steel has now officially launched FAMILIARC™ AF-490E and FAMILIARC™ AF-490AS.
This article introduces the benefits and features of using AF-490E in combination with US-29 SAW wire and AF-490AS with US-36.
Classification | AWS A5.17 F7A2-EM12K; F6P4-EM12K |
Features | Butt welding and horizontal fillet welding of medium and heavy plate |
Excellent notch toughness at low temperature down to -20℃ |
Polarity | DCEP |
Boniszewski basicity | 1.4 |
Shipping approval | ABS, DNV, LR, BV |
US-29/AF-490E is a solid wire/flux combination for welding mild steels as well as 490 MPa class high tensile strength (HT490 class) steels. AF-490E, an aluminate-basic agglomerated flux, exhibits excellent notch toughness down to -20°C as well as weldability in combination with US-29 SAW wire. Table 2 shows the details of US-29 x AF-490E.
2-1. Properties of all weld metal
Figure 1: Bead appearance
The chemistries and mechanical properties of the all weld metal are shown in Tables 3 and 4, respectively, and the bead appearance, in Figure 1. Even without the addition of any special elements, stable notch toughness can be obtained even at temperatures as low as -20°C.
C | Si | Mn | P | S | |
US-29 / AF-490E | 0.05 | 0.41 | 1.60 | 0.016 | 0.005 |
Note: Welding conditions: 550A-30V-42cpm; Ext=30mm |
0.2%OS (MPa) | TS (MPa) | El (%) | IV at -40℃ (J) | IV at -20℃ (J) | ||
US-29/ AF-490E |
AW*1 | 464 | 562 | 30 | - | Avg 119 (125, 113, 118) |
PWHT (620℃ x 1hr) | 380 | 494 | 35 | Avg 129 (142, 124, 122) | Avg 150 (154, 153, 143) | |
AWS spec.(AW*1 only) | 350 min | 490 min | 22 min | - | 35 min | |
Note: Welding conditions: 550A-30V-42cpm; Ext=30mm *1: As-welded condition |
2-2. Two-run welding of butt joint
Butt joint welding was carried out using JIS G3106 SM400B plates with a maximum thickness of 16 mm. The electrode arrangement is shown in Figure 2 . The welding conditions are shown in Table 5.
Figures 3 and 4 show the macrostructure and the bead appearance, respectively, and Table 6, the mechanical properties of the butt joint weld metal.
Figure 2: Electrode arrangement Figure 3: Macrostructure
Welding sequence |
Wire diameter (mm) |
Welding conditions |
Preheating and interpass temperature |
1st | 4.0 | 750A-32V-60cpm Ext 30mm |
Room temperature |
2nd | 700A-32V-55cpm Ext 30mm |
Figure 4: Bead appearance
0.2%OS (MPa) |
IV at -20℃ (J) |
IV at 0℃ (J) |
419 | 532 | 34 | Avg 116 (131, 121, 96) |
Avg 147 (148, 146, 146) |
2-3. Horizontal fillet welding
Figure 5: Electrode arrangement Figure 6: macrostructure
The electrode arrangement used in horizontal fillet welding is shown in Figure 5 and the macrostructure and bead appearance, in Figure 6 and 7.
Figure 7: Bead appearance
Figure 8: Relationship between welding heat input and leg length
The relationship between welding heat input and leg length is shown in Figure 8, in all available electrode diameters. In laboratory tests, leg lengths from 4 to 9 mm were obtained; however, users are recommended to aim for leg lengths of 6-8 mm, in consideration of groove accuracy as well as the stability of welding at actual work sites.
Diffusible hydrogen content (ml/100g) |
Classification of shipping approval |
N=1 | N=2 | N=3 | N=4 | Avg | ||
US-29/AF-490E | 2.5 | 2.6 | 2.7 | 2.7 | 2.6 | H5 |
Note: (1) Welding conditions: 550A-30V-42cpm; Ext=30mm (2) Test method: Gas chromatography (as per AWS A4.3) |
2-4. Diffusible hydrogen content of weld metal
The diffusible hydrogen content as measured by gas chromatography as per AWS A4.3 is shown in Table 7. One may note the extremely low level of 2.5 ml/100g and almost no fluctuation.
Classification | AWS A5.17 F7A6-EH14; F7P6-EH14 |
Features | Butt welding of medium and heavy plate |
Multi-pass welding only | |
Excellent notch toughness at low temperature down to -40℃ |
Polarity | DCEP |
Boniszewski basicity | 2.6 |
US-36/AF-490AS is a solid wire/flux combination for welding mild steels as well as HT490 class steels. AF-490AS, a fluoride-basic agglomerated flux, shows superb and stable notch toughness down to -40°C as well as good usability in combination with US-36 SAW wire. Details related to US-36 x AF-490E are shown in Table 8.
3-1. Properties of all weld metal
The chemistries and mechanical properties of the all weld metal are shown in Tables 9 and 10, respectively. Impact test results in the as-welded condition as well as after Postweld Heat Treatment (PWHT) are shown in Figures 9 and 10 by the transition curves, respectively.
Designed for optimum flux basicity, AF-490AS can obtain stable and excellent notch toughness at temperatures as low as -40°C even though no special elements have been added. The bead appearance is shown in Figure 11.
US-36 / AF-490AS | 0.07 | 0.39 | 1.62 | 0.014 | 0.004 |
0.2%OS (MPa) |
US-36/ AF-490AS |
As-welded | 516 | 598 | 32 |
PWHT (620℃ x 1hr) | 547 | 565 | 32 | |
AWS spec. (As-welded & PWHT) | 375 min | 490-660 | 22 min | |
Figure 9: Transition curve of notch toughness in as-welded
condition
Figure 10: Transition curve of notch toughness after PWHT
Figure 11: Bead appearance
3-2. Multi pass both side welding of butt joint
Butt joint welding was carried out using EH36 grade plates with a thickness of 20 mm. Figure 12 shows the groove configuration and pass sequence. Table 11 shows the welding conditions, Table 12, the chemistries and Table 13, the mechanical properties of the butt joint obtained via both side welding.
Figure 12: Groove configuration and pass sequence
Side | Wire diameter (mm) |
Pass | Welding parameters | Extension (mm) |
Face | 4.0 | 1 | 450A-30V-42cpm | 30 |
2-6 | 550A-30V-42cpm | |||
Back | 1 | 450A-30V-42cpm | ||
2-4 | 550A-30V-42cpm | |||
Note: Preheating & interpass temperature: 100-150°C |
TS(MPa) | IV at -40C(J) | Bend test *2 |
559 *1 | Avg 84 (81, 87, 83) | Face : Good Reverse : Good |
Note: *1: Fractured position=Base metal *2: Bend test: According to Shipping Classification Rule |
0.09 | 0.39 | 1.55 | 0.014 | 0.004 |
US-36/AF-490AS | 2.2 | 2.3 | 2.1 | 2.3 | 2.2 | H5 |
3-3. Diffusible hydrogen content of weld metal
The diffusible hydrogen content as measured by gas chromatography as per AWS A4.3 is shown in Table 14. The extremely low level of 2.0 ml/100g and little fluctuation is notable.
Diameter (mm) | Type | Weight (kg) |
1.6 | Spool | 10, 20 |
2.0 | ||
2.4 | ||
2.4 | Coil | 25 |
3.2 | ||
4.0 | 25, 75 | |
4.8 |
The package specifications of US-29 and US-36 SAW wires and the AF-490E and AF-490AS SAW fluxes are shown in Tables 15 and 16, respectively.
Mesh size | Type | Weight (kg) |
12 x 65 | Bag (Aluminum laminated) | 20 |
Redrying temperature | Redrying time | |
AF-490E | 300-350℃ | 1-2 hour(s) |
AF-490AS |
The redrying condition for AF-490E and AF-490AS are shown in Table 17.
This article has described Kobe Steel’s two newly-developed agglomerated fluxes: AF-490E and AF-490AS. Used in combination with US-29 or US-36, they feature stable weld metal properties and extremely low diffusible hydrogen content. It is expected that they will be applied to offshore structures as well as shipbuilding, both of which require sound and reliable welded joints.
